Discuss Adding new Honeywell IS312 PIR to Galaxy 20 Panel in the DIY Electrical Advice area at ElectriciansForums.net
Hi All - Does anyone know if I can add a PIR to an existing zone that has one PIR on it. If so with the pir wired as in the picture where do I attach the wires on the panel ideally I want to use zone 3 or 4.
I'm not sure if the original wiring is using same colours as I have for PIR.
Many thanks
Reply to Adding new Honeywell IS312 PIR to Galaxy 20 Panel in the DIY Electrical Advice area at ElectriciansForums.net
Hi there,
We have recently replaced our central heating programmer with a Honeywell ST9400C. We now want to replace our old wireless room...
Hi Guys
Got a job where property is set up with Honeywell evohome TRVs and controlled via central panel.
They're having an extension done with...
Hi everyone, first post here and in a bit of a pickle...
Newly qualified out in the big bad world...
I have a job 4 hours from the office so I...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
Hi everyone,
after temporary removing a Sonoff that I've installed years ago to do some painting, I'm unable to get everything back to work. I've...
