V
vardymr2
Hi everyone
I have fitted possibly 60 sub wylex D/B's with the Inepro meter built in the D/B. We installed one last week and Eon have refused the application because they are saying we can't them. I haven't had any problems before. I can not get in contact of Eon as they are now closed, Has anyone else had the same problem?
http://www.bis-electric.com/catalog/images/manuel_m32L.pdf
Lee
No, the Inepro PRO1D is MID certified which is a satisfactory and more modern alternative to being OFGEM approved.
Did Eon give a reason?
They have not given a reason at all, I going to give them a call in the morning as i have the MID cert for the meter.
Its just been one of them jobs everything seems to be going wrong for my client, The fronius 3.6tl packed up after 3 days so that needed to be replaced then this has happened.
There is one little tweak that not many people know. The V11.122 of that meter has no brake and will always count upwards whatever direction the power is passing through it. So the customer is actually getting paid for the few watts the inverter uses at night. The MCS metering guidance says:
"The meter should be fitted with a backstop so that it does not run “backwards” in
circumstances where there is power flowing to the generator.
Meters are to be installed according to the manufacturer’s instructions."
That is not the cleverest paragraph because it envisages the meter running backwars without considering the meter running forwards with each power direction.
Inepro do have a more expensive version which does not do this, but generally it does not seem to be stocked and Wylex do not seem to have appreciated the point. It is perhaps worth £10 per year in the customer's favour if I have my sums right.
Perhaps Eon have twigged!
Bruce is on the money as usual. The v11.212 is the better option as it's unidirectional only (with brake), with a back-lit display. Not typically stocked though but can be provided if needed.
Sorry my mistake its N power not Eon, this is what it says on the letter. Your meter type does not fall in line with the National Measurement Offices regulations...."
Any one use a wylex solar D/B
vardymr2,
BruceB,
