Electrical2Go - Online Electrical Supplier
Discuss Building Regulations breached? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Can anyone please, tell me is there any sign of breach of Building Regulations here? My new build has been built with space for a single meter box, however, a second one was installed at a later stage. The latest borescope inspection has revealed that there is no lintel above the second box and DPC or cavity tray is missing, also the second box is installed a lot higher than 1100mm from Gr.level. I have also noticed that there multiple unnecessary holes incorrectly cut (sharp edges) to cable entry position.
please, if is any qualified Electrical Engineer to give me some advice, I will much appreciate it.
Just a quick note: The house is still under NHBC warranty.
  • #3
Standard new build I’m afraid , some of the stuff I seen on new builds in recent years is truly shocking
Hello Sir.
Would this issue qualify as a breach in Building Regulations? I assume it will, but better check with a qualified Electrician before contacting NHBC.
Hello Sir.
Missing lintel supports , missing DPC , fire barrier breaches , any potential structural defect will fall under building issues not electrical problems
Midwest
Can I ask why the second meter box was installed and who requested it, bearing in mind this is a new build.
  • #6
Hi
I will never know why the 2 nd Box was installed, this is the way we got the House from new.
  • #9
It looks like it was installed to house the DP MCB protecting the SWA submain.
Is there any chance to explain to me in other words, please. Im not an electrician, Im just a poor desperate woman Who tries hard to understand what is right and what is wrong. So far I spent 6 months reading the Building regs, but it's still a lot to learn. All I know is if something is not right with a New Build, then We must be protected by NHBC. Sadly is not always the case.
Post automatically merged:
Where is your consumer unit (fuse board) located in relation to these meter boxes?
my consumer unit is on the other side of the house, 5 meters from the Meter box.
PEG
Mentor
Hi,who is the builder?
This may give us an indication of how much help you may receive🙂
I don't need any further information,however,to inform you that the NHBC will be zero help.
Midwest
Even a lay person can see that both these boxes have not been installed with any professionalism. Have you asked the developer to comment on the installation method and the various holes that have been left?
I don’t seem to notice any cavity insulation either. Is that not a requirement.
Midwest
That’s poor design then; because your CU is over 3 metres away from the meter, it will require a switch fuse to provide protection to that black cable. Something you don’t have, and something that should of had better design in the first place.
Do house of the same style of yours have the same set up?
davesparks
Mentor
Whilst it is a poor design choice the DP MCB in the top meter box will provide adequate protection.
This is something I dont understand, space in the 1st Box permitted to install everything in only one box.
In theory yes there is space, but in reality the equipment in the top box would have been fitted before the meter was installed and the meter fitters would likely have created a fuss if it had been installed in the bottom box.
  • #15
Yes, you are absolutely right, the insulation is missing. The developer can no longer be involved as 2 years have passed, this could only classify as 3-10 years BuildMark Warranty Cover from NHBC.
Instyle LED Lighting Specialists UK
Reply to Building Regulations breached? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Top Bottom
