Discuss Code 1 Problems - Am I being Scammed? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
by fitting a new CU, half of the remedials would automatically be taken care of just by installing it. i'd say £500 was nearer the mark for everything.
Heres the relevant pages of the report in image format. To be honest I dont mind paying the £150 + VAT for the cert but then having to pay additional for stuff that isnt needed is an issue for me.
Dark Forces,
Whatever happens you will still need to be in possession of a satisfactory PIR report and the the 2x code 2 deviations will need rectifying. So my suggestion is have a look through the listings on here a find a member in your area, or start a new thread looking for a spark in your area, 15,000+ members there must be someone in your area.
I would speak to your prospective agent and explain that the report carried out by their spark was far from acceptable and that you believe that he was trying to pull the wool over your eyes and extract money for a survey not completed to the required standard, and further trying to extract money for works that are not required.
I would put this to the agent, ask them is it something that they condone or support, i would mention trading standards, and i would categorically state that you will not be paying for the report. I would also go to great lengths to point out that the possible relationship between you and the agent is in serious jeopardy and that this may affect your business relationship, with them, going forward. by doing this you may find that the agent will be a little more helpful as a result.
Going forward, use your own tradesmen that way you have control of payment to them and you can be sure of where the tradesmen's priorities lie!, and you know the agent are not taking their cut.
Dark Forces,
OK thanks for that.. I did actually speak to the agent last week when the electrician had left and explained to him what the electrician had told me verbally. He explained that the electrician was just someone they recomended for this sort of thing and had no affiliation with the agency whatsoever. He did mention that sometimes the people they had reccomended could get a bit greedy with upselling their services and reccomending improvements that were not necessary but obviously the ownus was on me to make sure I did my due dilligence regarding this.
However in my opinion this is not just greed, its sheer incompetence and obviously I will be explaining to the agent I will not be paying for this cert.
what i would suggest is that you contact 1 or 2 local electricians for a quote for the remedials. make sure that you get a guy that's registered with napit, elecsa or niceic and ask for proof of this.
Reply to Code 1 Problems - Am I being Scammed? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello ! I am building for some time a cct to drive a 3digit multiplexed LCD. (from aliexpress) From the sellers on aliexpress I managed to find...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
Hi, So I'm trying to understand what's going on with my off-peak electricity supply, as something's wrong with it and I'm trying to determine if...
