- Dec 9, 2010
- 7,461
- 817
- 1,688
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
hi folks, im just wondering if any of your customers has asked you to have a look at a money detector. do you have any expieriences with these things.
i have taken the machine apart and checked continuity around the circuit, would the starter inside have to be rated as close to bulb size . its says on side 6w bulb but the strter is rated at 13w,25w-65w????
it also goes through a transformer of some sort can these be replaced, be great if someone know to fix or dump.thxxx
