N
newhousehelp
Hi I moved to a new detached house which is ~90 yrs old. It has RCB switchboard outside (Kitchen, lights, smokealaram) but I am not sure when the house was re-wired last.
My problem is that I need to lay a new floor. However the current sockets, sits just above the old skirting board which is only 5cm in height. That means, if I put new floor I ll not be able to put proper modern skirting (15cm in height) unless I cut the skirting around the sockets.
Do I need to do the whole house re-wired if I need the existing sockets to be moved up to Modern standard (45cm or 450mm)?
