B
bf2k
Hi all
I've recently qualified as a domestic electrician (hopefully going to leave the bore of an office 9 till 5 job soon). A family member has asked me to put some power & lighting to an outdoor "bar" area. It is fully weather proof and would only require standard IP20 fittings. However, I suggested that we took a new feed from his consumer unit (rewireable fuses - BS1361 cartridge fuses) out to a new 2 way sub consumer unit in his garage and split the feed into power and lighting. He's not keen in ripping all his floorboards up and having to replace everything. He's asked if we could possible utilise the existing power feeds going into his garage at the moment. When I did a survey of them a previous electrician has extended the first floor ring main to a FCU in the garage.
My question is, is it acceptable to extend the first floor ring from the feed into the garage and take it next door into the "bar" which will add a further 9 double socket outlets onto the ring (3 already on the first floor, each with an unfused spur) and take 3amp fused spurs from the ring to power the lighting? I've worked out in total they will be a maximum of 5 amps for the lighting. As far as I'm aware they isn't a problem with the number of sockets in the ring but its the use of FCU's on a ring main to power lighting.
I know it goes against everything you get taught on the courses but I can't find any references to tell me whether this is an acceptable setup or not. It would be a huge job to take a new feed out to the garage/bar from the Cons. Unit.
Thank you
Thank you
