Discuss I Need of Help Connecting LED Strips in the DIY Electrical Advice area at ElectriciansForums.net
S
Smelliot
Hello,
I have just purchased some LED strips from Amazon (link below), and I was wondering whether I could connect them up by firstly using a timer plug, followed by a 2-way plug.
The timer would be plugged into a wall socket.
The LED Strips: Tingkam Waterproof 1M 60 led 5050 White Color led Strip Lights Black Flexiable PCB With Connector DC 12V Under Cabinet Led Strip Ideal: Amazon.co.uk: Lighting
If you have any other questions regarding my plan, please let me know.
Thanks in advance for your help,
Smelliot
plug-in timer. then plug the LED PSU in after connecting the 12V plug to the red/black from the psu. note + and - must be the right way round. they're marked on the 12V plug.
I'm not quite sure what you mean.
Maybe I should have been more clear. What I am really asking is whether it would be safe to run two 12 volt plugs from the timer and a 2-way plug. As the LED strips will be left on for roughly 7 hours a day, I don't want to cause a fire or overload the wall socket.
ah, if i read that correct, you want to plug in a timer, then plug in a 2 way extn. lead then plug in 2 LED PSUs each feeding a LED strip.
Yes, that's correct.
Will that overload the socket? Or will it be OK?
The Amazon link gives the voltage and wattage of each LED strip.
it will be fine. don't use an adaptor, use a short 2 way extension lead. you can replace the fuse in the extension lead plug with a 5A.
Reply to I Need of Help Connecting LED Strips in the DIY Electrical Advice area at ElectriciansForums.net
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
Hi there, Please can I have some help with the following: I want to have some perimeter lighting in the ceiling which will be using the...
Wanting to add 2 strips of led lights down each side of underneath of the stairs, I have a socket I can spur off, into a fused switch, been...
I am trying to put some led light strips under the fenders of my fat tire E-bike. I’ve been looking at led light strips on Amazon, AliExpress and...
As the title says. But then I cut off a jst connection off one of the light strips and I can't get them to work together... the one strip is plug...
