Discuss I trying to add a breaker & my main panel doesn't have a Disconnect, How to I add it without getting electrocuted? in the UK Electrical Forum area at ElectriciansForums.net
Here is a pic of my panel.
Thanks!
not the same type of gear we have here, but we would carefully fit the breaker. tighten incoming terminal with a VDE insulated screwdriver, then, with the breaker OFF, connect the circuit. always be careful of touching live parts. if in doubt, consult an electrician. ( added to that. i don't know the regulations in Texas, as to whether you are allowed to do it. later on a couple of US members will be on to give better advice.
Here is a pic of my panel.View attachment 52549
Thanks!
Is that panel with the picture inside your house, if so do you have a panel located outside where the meter is. That’s where your main should be and it should be 100 amps
[automerge]1569448985[/automerge]
trucker john let us know what you find after my advice, I’m confident that’s what’s going on
@Megawatt,
Thanks for your response, The panel is outside of my house and right next to the city power meter. The panel in the pic has 2 2x50amp breakers and there isn't any other panels outside the house.
That panel was installed using the 6-disconnect rule, no more then 6 throws of the hand to disconnect power, and no main was required, just plain cheap but residential is as cheap as they can get away with, you cannot add any more breakers and be compliant with code, my advice is get the panel replaced with a main breaker model and consider a upgrade to 200A if planning to add major loads, load calculations should be done to determine if needed.
The 2020 NEC will require a outside disconnect on dwellings, although means nothing until it is adopted. :)
Reply to I trying to add a breaker & my main panel doesn't have a Disconnect, How to I add it without getting electrocuted? in the UK Electrical Forum area at ElectriciansForums.net
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
OK to add a 50 Amp breaker in this panel for a 220V EV Charger? Maybe swap some single 20 Amp breakers for dual 20 amp breakers? Can I add a 50...
Trying to connect a 50 amp inlet box to my Siemens outdoor combination panel 200 amp cutoffs. Can’t figure out where to insert the 50 amp breaker...
I'm starting a new construction single-family residence, I know with the 2020 NEC they require an emergency disconnect on the exterior of the...
