Discuss Identity of main fuse in the Australia area at ElectriciansForums.net
C
cymroaur
Can you help me identify this? Sorry the pic's rotated... the thick end is the bottom! TN-S arrangement, no markings on the case.
Any help appreciated.
Could be a couple of different beasts in there TBH, more than likely a BS 1361 type 2a @60A.
Doesn't look like there are any seals on the carrier though......:43:
Its a bit difficult to make that out but i would say its a bs1361 60a juding by the size but dont take this as gospel,perhaps some more members may be able to clarify,although i believe 1361 fuses are being classed as bs88 now,i dont have my regs book to hand,do you need to check the main fuse to see if anything can be added to the loading of the installation?
No. Put in a new radial, so need it for the install cert. I assumed it to be 1361, but I haven't come across these before so wasn't sure.
Well if there is nothing written on the casing of the carrier,then the next best thing would be to call the dno and ask for clarification,i know what i would do but not going down that road on a public forum.
Reply to Identity of main fuse in the Australia area at ElectriciansForums.net
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
G99 GSI-3 4.4 kw Victron inverter install with EES and batteries and installer can set the export lint if required by dno As part G99 GSI-3 you...
Hi all, I have been on a site repairing damage caused by travellers collecting copper for the last week. We have found and replaced cabling to get...
