Discuss jim - problem with the insulation and pvc cables in the Canada area at ElectriciansForums.net
J
jim murdoch
Hi Guys
I am working in a house at the moment which is geting refurbished the joiner who is installing Kingspan insulution tells me on his last job there was a problem with the insulation and pvc cables and the bcables had to be kept away from the kingspan insulation. has anyone came accross this before ????
hi jim,
yes ,"styrofoam" and pvc dont mix well,im not sure if the cable insulation would melt away compleatly in time .but it does get sticky,not sure as to a solution,best to play safe and price for o bit of pipe or trunking ,maybee
Came across this one recently,Kingspan does have a long term effect of polymer migration between the insulation of the cable and Kingspan.
Cause is insulation breakdown on the cabling leaving conductors without any insulation surrounding them and then operation of the protective device.
Plastic trunking and pipe is susceptible also
Solutions are metal conduit,trunking where applicable,or bare MI cable.
One other solution that i believe in use (never used it myself) is LSOH cable.
Although LSOH is more expensive it is certainly cheaper than a civil action.
From what I know it's only the polystyrene insulation you have to be careful of not the Kingspan type. Was trying to find the relevant reg as i've seen it before, but no joy...
Reply to jim - problem with the insulation and pvc cables in the Canada area at ElectriciansForums.net
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
Recently visited a new build to do a very minor job and spotted a few dodgy looking items so Client asked me to do an EICR. Following items I...
Hi We recently had an 7kW EV charger installed. Due to the consumer unit being situation within the kitchen of our bungalow, the cable needed to...
4K
Looking for some advice; I am intending to mount two led downlights on pillars/brick walls either side of the garage door opening. I will drill...
Hi, My son has just (last week) had a rewire done on his house in Leyland. He has just bought the house but a "domino" type consumer unit was...
12K
