Discuss Joining alarm cable behind plaster in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
A
andusbeckus
I have an new bay window and now the existing magnetic connectors for the alarm are too short to reach the window. The alarm wire needs extending but where the joint would be is going to be plastered over.
Is there any acceptable way of joining the cables behind plaster without having to pull it out and put a new piece in?
Reply to Joining alarm cable behind plaster in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
I'm about to start first fixing this fire alarm in the industrial unit we are wiring, at the moment its totally empty and eventually will have a...
Hi all, I currently have a Pyronix Enforcer V10 Wireless alarm system. I have some shock/contacts on windows, doors, PIRs, and an external siren...
