Discuss Multifunction Tester v Separates in the Electrical Tools and Products area at ElectriciansForums.net
E
Emm Eff
I'm just about to start trading and need some test equipment, basically the full kit to sign off a house/commercial property. Would it be best to go for a multi function "all-in-one" solution to save on calibration fees each year, or is it best to buy separates so that if one fails I still have the functionality of all the others?
What's the preference for a small business?
Are you allowed to link to product pages?
I'd be interested in first-hand experience that you fellas may be able to provide. I almost bought a Fluke unit there, only to see a review of three units going pop just after the warranty period. So, I thought I'd ask here and see what advice is available.
Thanks in advance.
Some people like separates, but I would go for an MFT every time, you are doing multiple tests and just rotate a dial rather than gutting out a new meter and set of leads.
If you lost one separate then you still would not be able to test an installation so you are in a similar boat with either choice, if you have the money then get a back up MFT!
my choice was a megger1552 MFT and a megger BM continuity/IR tester and BM7 analogue for fault testing.
There is obviously a preference for MFT, so I'm glad I've asked as it gives me some re-assurance.
What's the failure rate of MFT testers? Are they reasonably reliable? I see the Megger unit has a 3 year warranty, which is good... but as a small business I wouldn't want to be waiting weeks for a RMA turnaround.
I would go along with that , although I use separates. The only thing I would add is that you can use separates for other than testing if a multi is away for repair.
I have never used an MFT, all my test gear is separates, better for faulting I have been told.?
You don't need a PSC or loop impedance tester for fault finding, really just continuity and IR which is only part of MFT. That is, I would be looking to go with MFT for all testing and a continuity/insulation tester for fault finding.
You don't need a PSC or loop impedance tester for fault finding, really just continuity and IR which is only part of MFT. That is, I would be looking to go with MFT for all testing and a continuity/insulation tester for fault finding.[/QUOTE
True, suppose with an MFT less items to get calibrated too.
Reply to Multifunction Tester v Separates in the Electrical Tools and Products area at ElectriciansForums.net
R
We are about to start a large scale Periodic test and inspect programme of light commercial premises including three phase circuits. We are not...
Mike Blair
M
N
Hi, just learning and am about halfway through a domestic electrical course and need to practice my practical skills a little as I don't get to do...
Looking for some advice on what I've discovered is the electrics situation in my rental property. I'll note that before I moved in here I made...
11K
F
Hi everyone, After a loooong week we are all pretty ready to call it a day and start the weekend. It's been a hectic time here and there has been...
4K
Former Sponsor TM
F
F
Hello chaps I'm an ex-RAF engineer (electronics - TG3/4 for anyone ex-RAF), and then moved to offshore as a geophysics engineer (that was more a...
fall-apart-dave
F
