Discuss Panels on sagging roof in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
M
MikeXl426
Hi
I've got a roof to do a quote for, part of which is on an old part of the house which is about 4m wide. It has recently been re-roofed but still retains the old 'sag.' Over the 4m, it probably sags about 50-60mm at the centre. Now, I could discount that part of the roof but it could take up to four panels and make it more worthwhile for the customer.
So, if my structural engineer approves the roof for the loadings etc, can anyone suggest fixings/brackets that could be used to level out that kind of sag? I know brackets have some vertical adjustment, but the roof sag is a bit more than the brackets allow for.
Mike
Schletter have a whole range of different size rails that can span different distances, you also need adjustable fixings that can accomodate different mounting heights, also available from Schletter . If you try to span it in one, you will end up putting high point loads (dead and uplift) in the worng places and the mounting points won't be strong enough.
You'll need to be VERY careful with wind uplift with large varying gaps under the panels.
Schletter have a UK based team that you can call and they will advise you.
Reply to Panels on sagging roof in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
Hi all, I hope you can help me please. I had solar system installed nearly 2 months ago and my installer turned out to be cowboy despite having...
5K
We have this Swiss-made Dixi horizontal borer from 1957, very nice machine still with its original DC variable voltage drive. In those days there...
Is there a room in professional PAT testing for a business model other than 'per unit'? I ask because I've been giving this some thought. I've...
9K
Sorry for doing this as new members probably are a pain for doing this. Recently I had a new bathroom installed in my house. I don't know any...
13K
