L
Lonespark
Hi all got asked to do a pat job for client I under stand what I'm looking for check plug,fuse ,Lead,apliance for damage use pat machine we have this metro pat yellow box with three test buttons earth bond with a fuse selection and clamp I think pick half of rated fuse , insulation resistance and earth continuity my question is what is a bad earth coninuty result I rember microwaves gave high readings not to much intrested in job but for pice of mind would like to know more about pat
Earth continuity should not exceed 0.1 + R, where R is the continuity of the cpc in the supply cord and 0.1 is the resistance of the appliance minus the cord.
I doubt that has helped you at all as from your post I get the impression you are not competent you carry out the task required of you.
Na I'm a skilled person now pal just haven't talked about it since I was in collage and wanting to know more about it see a bit of company's just slapping on stickers left right and center eg pass sticker on old type plug with uninsulated l-n and so
I suggest a copy of the Code of Practice for in service testing of appliances by the IET.
Reactions: Rpa07
Don't you have the
Don't you have a copy of the ISITEE Guide??
What's wrong with that? The Code of Practice specifically states that they are permitted to remain in service - the unsleeved plugs simply cannot be reused.
Email
Time zone
Last seen
Pat job questions
Commercial Electrical Advice
Lonespark,
Risteard,
