Discuss Retrofit solution to solar powering an old large lampost in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
bigspark17
Could anyone recommend a set up i could use to power an old lampost using pv panel, charge controller, battery and BC led. The system would require some sort of dusk till dawn sensor or timer.
The lampost is in a very unaccessible location and cabling it underground is out of the question.
Could be a fun little project, i dont really want an adaptable box on the exterior but it could be used if small.
Ideas / kits sugestions welcomed
Reply to Retrofit solution to solar powering an old large lampost in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
G'day, In order to lower my electricity bill, I want to use the power of the sun to heat my hot tub. The setup is the following: A 100W solar...
I run a local charity raising cash to install defibrillators (AED's) around our small town in South Manchester - Most of the 14 we have installed...
LouiseIGC
L
Hi everyone, I have a quick question if I may? I'm thinking of adding a second PV system to my existing rooftop PV & battery setup. As the...
I have an outlet outdoor, supported straight up by a galvanized pipe. It has only black and white wires, no ground. The galvanized pipe is...
This is probably the most stupid question ever..... I have ''inherited'' some PV panels from the previous owner of a property... There are 7 PV...
