K
Kiers1970
Hi all.
Asked to do a job fitting lighting to bedroom furniture with sliding and normal hinged doors. Any of you done this before, any hints or tips, which types of switch have you used? Will be using, I suspect under cupboard type flous fittings.
I'll more than likely pick up the supply from a local socket outlet, as this kind of job takes time, and the cost can rocket for a relatively simple job.
Cheers.
Used jeani switches for things like lights in closets before.
Email
Time zone
Last seen
sliding cupboard doors/ Automatic lighting
Australia
Kiers1970,
Sparky Ninja,
