Discuss Solar Install developed fault in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Sargan
I have a 12 panel array … BenQ 330W panels, Solar Edge Micro-controllers and Inverter.
On Solar Edge App, shows 1 panel as not generating any output.
Panels & Solar Edge kit all under warranty but installation company has ceased trading … what’s my best approach, get an experienced PV electrician to swap over micro controllers on a good panel to bad ?Then if proven get a replacement under warranty.
Or is there a more logical approach?
secondly .. anybody in or know of a guy in S.Wales who could do this work ?
All 12 panels worked fine for since install (5 years)
One has ceased generation .... all other 11 working fine.
Suggested that it's probably the Solar Edge Optimiser fitted to rear of panel.
Check would be to swap out with one of the 11 good ones ... will prove if faulty.
Optimisers are under 25 yr guarantee by the manufacturer, but the firm that supplied & installed has ceased trading (like many PV companies)
Speak to the manufacturer,
they should be able to provide a list of local firms that support there equipment
On trawling through paperwork .... found (and not on contract docs) seems there is a warranty assurance mentioned ... under RECC Assurance scheme.
It does state that 'Pinnacle Renewables is a member of the RECC Assurance Scheme, we are required to have arrangements in place so that your workmanship warranty from us will still be honoured if we go out of business during warranty period"
These sounds initially good until the next section "Your warranty is insured under Deposit and Workmanship Insurance (DAWWI) Scheme You have a 5 yr insurance policy through QANW, covering workmanship and product"
So that has expired .... so I'm back to the beginning, and its product warranty direct with the manufacturer
Reply to Solar Install developed fault in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
TLDR - I have a system that is supposed to have optimisers fitted, but I am not sure they have been fitted. The detail: Back in March I had a...
So, I already have solar (an older FITS installation) and it's been particularly successful so I want to extend this. I'd like to do two things at...
Renewable energy startup is seeking a Technical Co-Founder to help create a company that is both socially and financially rewarding. The...
Hi guys, I am new to the forum so be nice! I used to install solar PV systems back when the tariffs were still good, and I've never had to go...
5K
