Stevie g
- Reaction score
- 18
Did a periodic today property out in the sticks, solar panels fitted with battery back up. In the met outside cab 2way DB off mains with a RCD main switch.ct1 feed solar panels.ct2 feed to 4 pole iso LN in LN out to supply batteries and batteries LN out back into said iso LN out to 6A rcbo in separate enclosure next to house DB from this 1.0mm t&e into house DB into connectors with 3 lighting circuits 48 lights in total. It's not how I would do it but is this common?
