M
MCS Renewables
Next week we are removing a solar edge system that has been on test for just over a year alongside an SMA inverter with an identical system.
The Solar edge solution promises "25% more energy" yet delivers less and costs more.
Thankfully we have none of this product out with our customer base as we have always opted for Enphase as we liked the no single point of failure and better warranties.
A similar thread is here :-
http://www.electriciansforums.co.uk...lar-edge-vs-string-inverters-performance.html
Enphase v Solaredge here :-
https://www.youtube.com/watch?v=q17vH1mNpDQ
I agree with the sentiments re solaredge, but am a bit confused why you then make the leap to enphase.
for information, I had some discussions with enphase which resulted in them admitting that they had effectively rigged their side by side comparison tests by comparing with an old low efficiency SMA 3300 inverter rather than comparing against latest generation higher efficiency string inverters with optimal string voltages etc.
We will use enphase in some limited situations, but have found that the SMA & Power-one dual tracking string inverters with the full scan shading functions enabled offer very similar performance in shaded conditions on a correctly designed installation at a much lower cost.
Enphase make a lot of their shade performance, but in reality due to their voltage range they can only function with a single bypass diode operated, so as soon as they have shading on a 2nd string of cells within the panel they can't bypass it, and will end up with the panel performing at the output of the shaded cells instead. The SMA or powerone with full scan function enabled will bypass all shaded sections and allow the rest of the array to function at full power, so I'm really not convinced about the benefits of enphase either, and deeply suspicious of their need to use a 10-15 year old string inverter as their comparison rather than doing a fair comparison with the latest generation of string inverters.
I do like the portal side of things though, just wish we could get some actual reliable performance comparisons as opposed to the obviously biased data they supply.
I'm aware that BRE are doing comparative tests for enphase, unfortunately I'd expect that the results will only be released if they are favorable to enphase - if no results are released this year, then I'll be working on the basis that the tests didn't prove very favorable for them.
- - - Updated - - -
ps this thread is crying out for graphs please ;)
OOPs. wrong sort of graff. :90::oops:
I have done a handful of Solar Edge (SE) installs and been pleased with them. Sadly I do not have good comparative performance data that will settle the argument one way or the other. But the SE solution seems particularly good where individual panels at a time get taken out by a shading obstacle or where you have multiple inclinations/orientations.
I do not trust the video linked to above. Seems rather typical American style advertising where you knock the opposition. There are many misleading points made in it.
Also, I read the side by side comparision report on the Metgen website and do not trust that. It looks like the SE arrays were set up with the minimum and the maximum number of optimisers so they were operating at the boundaries of their permissable range rather than a more typical mid-range where efficiencies peak.
I did consider micro-inverters on the last SE installation I did before Christmas, but as the number of panels increased (beyond say 8 or 9) then the micro-inverter solution became uneconomic compared to SE.
Long term, I am concerned having all the electronic complexity on the roof with micro-inverters, certainly if access is restricted. A power optimiser is much simpler and to my mind less likely to fail over say 25 years. Having the inverter inside in a more environmentally stable place seems a good idea to me.
I share your concern over the points of failure on a roof over 25 years but I'm surprised that you believe a power optimiser is more likely to last than a MI. The Enphase MI are encased in resin, as I understand it, something which the SE optimisers are not. Enphase seem to think this will give them better reliability.
And to be fair to Enphase, they do seem to back this up with their warranty. Enphase will send a guy out to repair any MI which fails in the first 5 years; still not as good as I'd expect, but better than SE (although they are improving this aspect this year)
Unless there is better evidence, then optimiser is half the price and under half the weight of micro-inverter, so probably has about half the number of electrical components, so probably is twice as reliable.
I am glad Enphase are putting their money where their mouth is. I hope it turns out to be a good product. I am not making specific criticisms of it as I have not used it. I was a bit irritated by the video as that and all the contacts/marketing over the last year seem a typical American style assault on the market with the aim of denigrating/wiping out the opposition and then cornering the market at leisure.
We've used Solar Edge a few times and have been happy. No failures yet and the monitoring is great. Support from SE has been good whenever we've contacted them. We use it on jobs with panels on 3 or more roof surfaces. None of the jobs we've used SE on would have been possible with one string inverter. We don't use it to overcome shading issues.
Here are SE's videos promoting their product.
A comparison between SolarEdge power optimizers and microinverters - North America Version - YouTube
Enphase VS SolarEdge on Vimeo
They used 240w panels which wouldn't favour SE and are almost impossible to source (except Panasonic) in this country. A 250w panel would have been preferable.
They also only used 8 panels with a SE3000 which isn't great matching. Better to either use 12 panels or go for the SE2200.
Totally biased and unreliable report.
Apart from the technical arguments, the warranty and monitoring almost make the extra cost worth it anyway. We've done quite a bit of SE because most of our jobs are on multiple roofs or have shading that's a bit more complex than a twin tracker can cope with. It's not something we recommend for bog standard installations but for the others it seems a reasonable compromise.
We're looking at Enphase too but it always seems to come out that bit extra and we're still a bit nervous about increasing the price too much.
This graph from solar edge's test document demonstrates the problem I referred to with the microinverters in that they can't properly track situations where more than 1/3 of the panel is shaded due to their operating voltage range.
That's an interesting point in SE's favour. I wonder how much difference this actually makes in annual yield. I would guess not a huge amount.
not just solar edge, it also works in favour of string inverters as long as the MPPT tracking can cope with bypassing multiple strings of cells at once - ie it needs either to have a wide standard MPPT range, or a full scan function every few minutes to track for the true peak and avoid getting stuck on a false peak.
About the only thing micro inverters have going for them is that they will allow for generation from fully shaded panels, whereas string inverters functioning correctly will bypass the entire panel.
As the output from fully shaded panels is going to be in the region of 10% of the output from unshaded panels, it's of fairly marginal benefit.
And this is why neither enphase nor Solar Edge will actually run fair comparison tests between their systems and dual tracking SMA 4000TL-21 or Aurora Power-One 3.6 Out-D inverters with the full scan function enabled, and actual shading tracking across the arrays as it would in reality. They have to rig the tests in their favor by not using a dual tracking inverter in order to demonstrate the supposed superiority of their technology.
Lol its always a nice twist when the company at the focus of the thread comes in to bat for their corner.... its not my field but i like a good bit of banter from both parties ;)
Popcorn ready :bucktooth:
Reactions: 1 person
Here we go guys I am going to throw my hat in the ring and hear the bell ting,
So here is my opinion of the sittuation
Micro-inverters, to me must contain all the components you would normally find in side a typical string inverter, the position of the micro inverter concerns me, sitting behind a panel which in peak sunlight will be in 50+ degrees surely must reduce the life span with no heat sink or fan, in my humble electrical experience, electronics and heat don't mix so surely a system with less electronics at this point will be more reliable and surely give better performance which the solar edge optimisers do. I personally don't like the trunk cable and accessories that come with the enphase kit, it has not been tested as much as the MC4 connector which has been in use to good effect for a long time. As for warranty the Solar edge inverter extension to 20 years is £150 plus vat which still brings it below a enphase kit. Finally imagine the ac trunk cable getting water ingress and tripping out rcd if not on a designated 1 way unit this can be costly, also fault finding will be more difficult in the fact you will have 3 cores going round each panel instead of the traditional single core dc cable. A lot of this relies on the installer and may be not the enphase product, but for me i prefer the solar edge setup for price, and the fact less can go wrong behind the panels due to less internal components.
Also my last tip is to check the financial background of both companies, i know solar edges fills me with more confidence than the later
Hi All,
I had a SolarEdge SE4000 system with 16 x 235W panels and 250W optimisers commissioned 1st December 2011.
The system failed 15th May 2012 when two optimisers failed and £850 of scaffolding was required to get access. The two faulty 250W optimisers were replaced with 400W optimisers.
The system has failed again 7th June 2014. With only 9V dc being displayed on the LCD I guess more optimisers have failed and another £850 required for scaffolding.
An initial attempt to re-pair the optimisers worked for one day, but now won't work any more.
I did notice the installers had left a large coil of wire at each end of the string and was wondering if this would act as an inductor causing power spikes, as I live under the flight path at Gatwick and at this time of year landing flights can pass between the sun and my panels. Unlike a slow moving cloud the shade is instant and short lived. 360V 10A DC on-off-on every time a plane pass over.
This failure is only 3 weeks different from the last one????
Any thoughts?
Regards, Trader9.
That's one of the reasons we've mostly stuck to string inverters.
I'm not that up on these systems, but I thought if one failed it would just bypass that one and the rest would continue to work. If that is right, then it'd look to me more like one of the DC connectors on one end or t'other of the string had failed, which has been happening a bit with installers who've not been fully tightening the waterproofing gland on the dc connectors, allowing water to get in and end up with a high resistance joint followed by the connector burning out in a period of prolonged peak output. If it is this, then it'd have been a problem even with a string inverter.
If you've set up the online monitoring, it should be pretty easy to see the relative performance of each panel. This should help you to identify which optimiser to investigate.
If you tried re-pairing and it doesn't work, you might consider the SD card. Ask your installer to contact the UK Support Team with the serial number of your inverter and ask for an updated activation code which they will email to you in a day or two. You then need to remove the cover from the inverter, extract the SD card (located near the screen), delete the original file and replace it with the new one. Here are the step-by-step instructions they sent us when we had a similar issue a few months ago. Following these instructions resolved our problem and the system has worked fine ever since:
"Following our phone conversation I am sending you the required file and procedure you should follow.
I have attached a file, please follow the next few steps:
1. Put the file on a SD card.
2. Turn off the inverter DC.
3. Wait 5 minutes
4. Turn off the inverter’s AC
5. Put the SD card in
6. Turn on the inverter’s AC
7. Using the configuration buttons- go into “maintenance” menu and choose “factory reset”.
8. Turn on the inverter’s DC
This should take care of the issue."
Not surprised to see people on here starting to moan about Solar edge failures.
There is a company is Wales, we know, who have had over 120 optimiser units fail so far. (Out of 2000 or so installed)
Most are green on the inside when you take them apart which suggests some form of water ingress. They are only IP65.
We have over 110 Enphase microinverter systems and have had only ONE inverter issue and that`s because a squirrel ate through the cable, which is hardly the manufacturers fault. Thats 110 systems say 10 micros on average so 1100, issue free.
No news here .............You get what you pay for
We have installed over 250 solar edge installations, had 2 failures on the optimizer front and 1 duff inverter both replaced within a week. The support and back up along with the training side of solar edge is in my opinion the very best. I called the service engineer on a sunday and he even had a look into a high grid voltage issue we had and fixed it via the internet connection. A lot of installers will not be connecting these systems to the internet, we have all of ours connected up and it enables us to see what fault codes are present if any and if optimizers or panels are having issues. To be honest anyone can slag a product its very easy and all products will have faults and issues. Everyone has there chosen products.
SO NO NEWS HERE EITHER, YOU DO GET WHAT YOU PAY FOR.
Reactions: 2 people
Hi All,
Thanks for all your remarks. I have contacted the installers this morning and they are going to contact SolarEdge so they can do a remote investigation first.
Before any scaffolding goes up etc. Last time it was thought the inverter was at fault and it was swapped out to no avail.
With only 9V DC showing on the LCD panel my money is on a faulty optimiser or two. When I re-paired the optimisers on Saturday all panels worked and generation was the same from every one. So there was no clue there. But on Sunday the re-pair trick failed and I have had no generation since. Most panels show about 5W, but panels 2, 9, 10 and 13 show 0W but I am not sure this means a lot.
Lets see what SolarEdge can find with their remote investigation. I have a Cat5E network around the house and had installed a socket in the loft prior to the install so the inverter has always been connected so a full history should be available.
Regards, Trader9.
This sounds like a possible optimizer issue, also could be the communication board inside the inverter, The only faulty inverter we have had out of 250 was the communication board which was replaced.
I am sure the guys at solar edge will assist you, is your installer not available to assist you on this?
Solaredge - Waste of Money
MCS Renewables,
wersolaruk,
