Discuss Thin-film panels, anyone using them? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
S
solarcat
Before crystalline panels had started dropping in price there used to be a lot of interest in thin-film...
Usually lower efficiency (which doesn't actually matter if you have space) but also lower price than crystalline...
Just curious whether any of you use thin-film panels and whether you could recommend a supplier?
Main question is whether the current price difference between crystalline and thin-film makes it worth using thin film panels. Lower efficiency means slightly more BoS cost, but if panels are much cheaper this can still be justified...
I can find Heliosphera, Inventux, Pramac, Astronergy, Avancis, GE, CSG PV Tech on the MCS database, but have not managed to get hold of any price nor availability info yet from UK distributors
Fitted a few now...bit of a ball ache getting the right fittings and the sparky needs to know his onions. Look amazing though...check out Q Smart modules from Q cells.
Reply to Thin-film panels, anyone using them? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
We have solar PV panels (1.5kw) and I'm curious about fitting an immersion diverter to use any spare solar energy for heating water rather than...
Was wondering if the gurus can critique and/or provide recommendations on my plan to install two sub-panels in a (50'x100') 5,000 sq ft steel...
Hi, I've got both a solar pv and an ashp system. The solar system also has 2 batteries and it's configured to fill the batteries first and then...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
