Discuss type fitted breakers in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
MG201
i see that in the 18th edition there is now a coding for type fitting , i have been coding any mix and match breakers as code 2 , after contacting lots of manufacturers there guidance is always that they have not type tested any other manufacturers products for there boards, as we know many breakers are manufactured in the same factories and then branded afterwards so they are the exact same product except for branding, when this is the case i code it as a code 3 , would this be the correct logic or shouyld it be code 2 all the way ?
Then that means that it fails if it is a c2, if not replaced for like for like mcb. I have to say being a electrician now is more pain than it's worth. Some mcbs are hard to get a hold of.
I do not think the Reg books work in that way, unless 18th is different.
More likely be mentioned in Guidance note 3, Inspection and Testing.
If it's a new regulation then it should be in the BS not an inspection and test guidance, imo, just saying.
I know of only one piece of Coding advice in the 17th which remains for the 18th that when reporting for an EICR you are advised to give the absence of additional rcd protection for older installations the minimum of a Code 3. I am pretty sure I know what he is alluding to though.
Sorry, I mean there is a 18th edition updated guidance note 3. To match the new Regs. I can't imagine it says in the new blue Regs book, codes for different mcbs. The Wiring Regs don't do things like that.
Sorry, the OP wrote it in the question that there is coding in the 18th. He must have a book and as I do not. So there must be more coding relating topics in the Electricians Bible. An expensive Bible, give it 6 months for a new amendment. ÂŁ95
No mate I think he is referring to the statement that came out of the NIC presentation that you shouldn't mix makes of OCPDs in the same board.
And what reg number did they state to back this up?
What about the same "products" with different names on them?
I do understand where the busbars don't line up etc BTW
Reply to type fitted breakers in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A recent thread on the suitability of a cable supplied preinstalled on a manufactured floodlight/pump had me wondering a few things. Over the...
I need to replace two AFCI breakers on our main circuit panel. I have replaced and added breakers to our sub-panel several years ago. When I...
I am going to be replacing two AFCI breakers after a lightning strike in a house built in 2003. I will be bringing the breakers with me to ensure...
I am an NICEIC contractor but I have never installed an Electric vehicle charger. I have watched all of the relevant NICEIC webinars (The wire) on...
I have had these lights installed by a contractor whose work is normally very good. He has not connected the earth in each fitting as there is a...
