A
AdamKerr88
Evening All
I've come across a very unusual situation; I've recently been asked to do a consumer unit replacement on a job but on inital inspection i've discovered that the systems only connection to earth is via a 16mm2 cable between the MET and the netural connection within the henley block. At first i assumed this must be a PME system, however i've only ever seen this done by the DNO within the cutout and never a direct connection to the netural, also there in no sign warning of a PME system.
Has anybody come across this before or is this a serious defect as i suspect...........maybe a home made PME earthig terminal on a TT system :S
Any ideas?
Adam
Any ideas?
Adam
