Discuss volt free in the Australia area at ElectriciansForums.net
V
vinny electric
can anybody tell me the point of volt free boilers i have done a lot of boilers over the years but not sure what the point of this is ???????
thanks
:banghead:
I may be wrong, but the way its been explained to me it. It saves the user from any chance of an electric shock if they touch broken buttons etc with wet hands bla bla bla. Better than 230V through a switch if you can minimise all risks then it is ment to be safer?!
In all fairness once you have your head round it, it is actually fairly easy to understand. All control panels i build at work now have to have volt free switching with illuminations being seperate and a solid button.
I have some wiring diagrams i can email you showing how volt free switching can used in switching simple 3 phase contactors, relays if it would be of any help.
Mike
Reply to volt free in the Australia area at ElectriciansForums.net
I want to connect one panel 12 volts (south west) with 2 panel that are in series 24 volts (south) in parallel to a 24 volts in controller. The...
Hi, I have lifetime experience (50+ years) in United States with basic knowledge of split phase 120/240 volts replacing wall switches and...
Good afternoon, I have a 2 year old car battery (AGM 760 CCA) in a 2022 Hyundai that constantly "seems" to lose its charge. I'll check the...
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
Just looking at my boiler wiring out of interest, and just wondering if it's wired correctly. So perma lives, neutrals and earths in the right...
5K
