James Riley
- Reaction score
- 3
My well pressure switch would not cut out so I replaced it with a brand new one (on at 40 lbs, off at 60 lbs) and made sure my pressure tank was at 38 lbs. No Joy. I tested all wires and found that all connections except one were 120v, as they should be. The cut off switch wire is at 48v. Since everything above ground that I can test seems good, should I assume there is a short down the well hole? Attached is a photo of the inside of my control panel. As stated, all is 120v except the red wire on the far left of the relay (SW), and the white wire on the right side of the little box in the upper left of the panel.
Second question: My pump motor has been running constantly this whole time, even when there is no draw of water. Isn't that going to hurt the motor, or is it okay? Pressure is at 75 lbs, which my lines can handle. A well guy said my pump moves enough water by the motor to keep it cool even though there is no draw, but I don't understand how any water is moving at all if there is not draw up the hole.
