jimmy23
Hertfordshire
I'm homeowner and moved into a property which has 25 halogen downlights, I'm hoping to get an electrician to replace these with LED ones, what sort of cost am I looking at excluding the materials?
Without needing to enlarge cutouts, I should be able to find something which fits in the existing holes.
I'm posting here because if the cost is of my reach for the time being, I can just get on with ones we have till I gather some funds without wasting peoples time to come over and giving quotes.
Thanks.
Forgot to add.
location, Hertfordshire, SE.
Have you investigated whether they are 230v downlights or 12v downlights with a transformer?
Have you considered just swapping the bulbs to LED?
Yes they are 12v downlights with a transformer, I tried swapping them with a GU5.3 LED but they start flickering, I read Phillips bulbs apparently don't flicker but I thought best to get them all replaced with GU10s and have a fresh start.
I can swap them myself but not sure if this is permitted nor I have necessary knowledge and equipment to test the work.
£250 ish is what I was hoping for, thanks for the replies.
£10 a light assuming no nasties like really short cables that all need extending then the job becomes much longer, £250 would be my best price, I wouldn't bother for less
What i tend to do is simply cut the old light off if there is lots of nice slack on the cables and then stick a click flow on the ends. then flow on a bit if 1mm flex and then flex to light.
15 mins per light
obviously i will be charging for the flex and connectors
Reactions: jimmy23
Swap the lamps to led you also need to swap the transformers for drivers and change the switch if its a dimmer
Sure. My thinking was the size of this task depends on whether the customer wants to retain a 12v setup or not. I was only intending to suggest swapping lamps if they were 230v.
Reactions: jimmy23 and Markyd
Hertfordshire
What is the expected rate to replace 25 halogen downlights with LED ones?
jimmy23,
timhoward,
