Discuss What is the name of this circuit? in the DIY Electrical Advice area at ElectriciansForums.net
Hello,
I am looking for the name of this type of circuit and how it gets wired. If it isn't too complicated it may become a DIY project but want to be able to know what I am looking at if I hire a pro. I have two 120 volt single medium lamp socket wall sconces. I want them on either side of my bed. I want to have switches on both sides of the bed and be able to turn on one, or the other or both on or both off from either switch. I have seen this in hotel rooms and they are usually on either a click switch or a turn switch (assuming a relay of some sort). Is this possible with a toggle switch and what would you call such a wiring design?
Reply to What is the name of this circuit? in the DIY Electrical Advice area at ElectriciansForums.net
Greetings. I am new to this forum and I have a question regarding a relay that I am installing on a motorcycle wiring harness. What I'm trying to...
Trying to install a Lutron Toggle/Dimmer (TGCL-153PR) Confused, as the current switch has 3 wires gong to it Black, White, and Red (there is also...
I have a bathroom fan with a moisture detector that turns it on and off. It also has a control circuit to turn it on/off when moisture is not...
Hi, So I'm trying to understand what's going on with my off-peak electricity supply, as something's wrong with it and I'm trying to determine if...
Hi folks, I’m new to the forum and it’s this issue that lead me here. So first things first. I was looking to wire in a Smart Relay at the rose...
