HappyHippyDad
Supporter
Dec 18, 2011
5,379
6,732
405,788
Gloucestershire
Morning all..
Heading off to work very shortly so any ideas over the next hour greatly appreciated :-)
I have a 60m drum of swa that wont fit on my normal spooler. Any clever ideas for a make shift one for the day? Something involving a broom handle I expect :-)
Depending on the weight, you could make one out of 20/30mm metal conduit and angle box's? Or for a temporary solution, use a piece of scaff bar across two sets of step ladders?
Jay
Reactions: HappyHippyDad
A couple of appliance roller skates (not the full width top ones) upsidedown on bricks.
Conduit bar through an A frame ladder if you don't have two ladders.
The pipe vice on a conduit bender is often more useful than the bender itself...
Was that a stock photo you had or did you rush out to set it up to show HHD - either way Good Job.
Stock photo I had. And cheers :) You need to put a saddle or summat on the conduit to stop the drum fouling on the legs of the conduit bender because of the angle of the vice, so it spins freely. But it works really well, and can cope with pretty big/heavy drums.
Ha ha, I just realised this was happysteve!!lol I thought it was HHD posting his solution, hence my post above about the small SWA drum.lol
Note to self, I must read more carefully!!
Jay
lol :) It's a 50m drum, but only 4mm 2 core.
Reactions: Jay Sparks
Here’s one I made earlier. Scaffold bar was hung from a large tree and then wedged into the wall. Supprising it worked well. Cable was about 60m of 16mm 3core swa
2 apprentices and a scaffold pole works well. ghas the added advantage of stopping then texting in working hours.
Reactions: happysteve
HappyHippyDad
Supporter
Gloucestershire
Any clever ideas for a make shift cabel holder/spooler?
HappyHippyDad,
7029 dave,
