- Reaction score
- 5,628
I have fitted RJ45 connectors to either side of a piece of cat5 cable but when I test it on the laptop I get no ethernet connection. I also have a pre-made ethernet cable which works fine so I know it's my home made ethernet cable. I cut the cat5 to 12.5mm and connect both ends the same (i.e s68A)
I have practised this a few times now each with the same result, i.e. it doesn't work.
With a piece of twin and earth I could test for continuity at both ends but how do I test for continuity through an RJ45 connector?
The problems that I can see it as being are the following but I dont know which is the most likely or if there are other problems I missing?
1. Poor quality connectors, not actually making contact in the laptop or router.
2. cat 5 not actually terminated inside RJ45 connector
3. RJ45 Crimping tool not effective which leads to 2 above.
Cheers all.
Cheers all.
