A
agi1190
Hello everyone.
I'm getting a bit desperate, as my car has been at mechanics 3 times already and nothing really helped.
Here is the problem:
My 2009 Citroen C2 has an electrical/electronic fault which no one can find so far. The car sometimes starts with no issues whatsoever, and sometimes almost nothing will work - central locking is not working, when the key is turned in the ignition, there is a number of faults displayed: "braking system faulty, airbag system faulty etc." and turning the key in 3rd position (to start the engine) does nothing - not even a click of the starter motor.
And then a few days later - out of nowhere, It might wish to start again with no problems at all. And once it was running, let's say to go to the shop, once done with the shopping it won't start again.
Last week a car electrician replaced the fuse box and the car worked for a couple of days and then the problem came back again. Had my car towed twice, it cost me a lot of money already to recover and diagnose the issue, which couldn't be found (some errors displayed, but nothing specific to help the mechanic to find out). Some suspect a faulty BSI unit, which would need to be repaired, however, the car electrician says if that was the case, the fault would be constant. He suspected faulty/damaged wiring or a fuse box - which he then replaced. All professionals said that there is no visible water damage to the system, so this shouldn't be the problem.
Also, there is a strange noise coming out of the stepper motor while the car is faulty, I'll try to attach the short video with it.
Please help, I am really desperate, only had this car for a few months and if I even to try to sell this car I need to get it running...
I would really appreciate any help or ideas you guys might have. I know it's a bit vague, but this is the only information I have as I am not a professional.
- TL;DR
- Citroen C2 starts whenever it wants, electrical fault coming and going, fuse box replaced and didn't help, possible BSI fault, but not sure. Please help.
