stevef22
USA San Antonio
United States of America
Hello, I recently swapped out 6, 150w 1X2 flat LED pannel shop lights. They had a 1-10v dimmer line installed.
I upgraded to 6, 200w UFO style LED high bay lights. Replaced each wire 1:1 taking my time to make sure each has a good connection with wire nut and black electrical tape.
This morning after about 1hr the first light goes out and the rest are dimming to about 30%
Could it be my dimmer switch? What switch do you reccomend?
Here is a detailed drawing of the issue
Thank you
Have you been up to check your connections?
Try changing the dimmer to a regular switch, to test it.
Not all dimmers work with LED…. And not all LEDs are dimmable
Maybe I'm reading this wrong, but aren't you trying to control 1 - 10V protocol dimming lights with a conventional waveform chopping dimmer switch. The dimmer switch you've arrowed appears to be a conventional high wattage dimmer.
Thank you
Is your dimmer rated for 1200 watts?
USA San Antonio
Installed 6 new high bay lights. One went out already. Dimmer question
USA Electrical Forum
stevef22,
Megawatt,
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
