L
liamj2003
I am wishing to extend and install some new sockets close to an existing socket in a room, I am a complete newbie when it comes to electrics although sensible and aware of the dangers, I want to install some additional power sockets in my living room but unsure what wire i need to use.
I am aware that this is an easy question but i dont know the answer so appreciate the help and if a few people could answer to confirm its right.
Once i know ill order some on ebay.
Many Thanks!!
Or a "ventilation engineer" - sucking air in and blowing it out again. Easy. Anyone who can breathe can do that.
Typical spark, can't read.... only quote. Often incorrectly. :)
I put my ventilation work as secondary, and my electrical work is perhaps tertiary.
My main business is refrigeration and air conditioning. Unfortunately we can seldom find "electricians" who understand the schematics of the basic control strategies we use in simple BMS's...........so I have decided to employ and train my own......
If any of you specialist are up for the challenge...
Steve
Things you need to consider when adding extra sockets.
Is it a ring or a radial? Are you going to spur from the ring? What is the flc of that circuit? Do you need additional protect (rcd)? The Zs, VD, Cg, Ca, Ci, Ct, If, It, In and the Ipf of the cable? Is the Zs within limits? After installing it can you test it, give a cert and notify the works?
It may not be rocket science but there's more to it than just banging another socket in the wall.
Reactions: 5 people
Steve
Well you are my new hero!
Steve
Sorry, did I miss something?
I can do air conditioning - you don't need to "understand the schematics of the basic control strategies we use in simple BMS's" it's all plug & play, a monkey could do it.
Yes, 'O' Level physics is all you need to understand how electricity works. Play around with a bit of constantan wire and understand electron flow. Brill.
To ensure electricity is safe, that's another ball game entirely.
When there's a problem with water pipes, there's a leak
Problem with gas, you can usually smell it.
Problem with electrics... oh wait, someones just died from an electric shock or a housefire.... Were there any warning signs? No.
But wait, "the electrics were working fine before that happened".
Reactions: 2 people
Judging by this response a few birthdays. How old are you?
:) plug and play :) now I know at exactly what level you ply your trade. You may be able to baffle Mrs Green when her door bell doesn't work, but you will have to step up a gear if you want to work in the trade.
LOL Plug and Play Lolllllllll
Steve
Steve
Steve you've only just past your 2382? Your condescending comments on this subject is not warranted. Sounds like you've had some bad experiences with sparkys that you've employed. Are you sure they were rubbish or was it the management?
Steve
A domestic installer could install a fan, it's really not as difficult as you're making it out to be.
I seem to remember there was an article about 'installing' air conditioning in professional electrician magazine recently - these new systems are a piece of cake to install and a lucrative way that electricians and installers can diversify. You don't need a degree in astrophysics to blow air around a room.
I fully agree. You can't smell it, often you can't hear it and it will kill you. It should be treated with respect. The problem is as far as I can see it it that you guys have made it out to be far more dangerous in every day life than it actually is.
What is more dangerous?:
The OP buying a load of 4 way extension leads and running them all around his house?
or
The OP asking advice from what he perceives as a reputable forum of professionals, on the correct way to perform a simple wiring task that is no more difficult than wiring a plug?
The guy needs a few extra sockets and one way or another he is going to get them.
or
Don't diss electricity, it can be almost as dangerous as a room with a draught which blows in slightly the wrong direction because the "engineer" has got the angle of dangle wrong on his air vents.
You are correct, but you will soon need a C&G2079.
That article was the best thing that happened to our trade last year. We had no end of calls from electricians and plumbers who has **** themselves and lost the gas. Every other spark in the wholesalers had frost bitten fingers. :D
Steve
or
Typical joe public response i'm afraid. There are a dozen or more factors to consider before putting "just an extra socket" in someones home. In some ways extension leads are preferable... At least they'll be protected by 13amp fuses.
What wire to use when spurring a circuit onto additional sockets?
Australia
liamj2003,
davelerave,
