L
liamj2003
What wire to use when spurring a circuit onto additional sockets?
I dont want to reopen this thread for discussions on ego sharing... but to let you know
1. I'm not dead or flame bait!
2. Wasn't aware until just today of the discussions that followed the orginal thread.
3. I purchased 2.5 t+e as first recommended from B&Q and was recommended it by the electrical guy there when I asked what to use.
4. I started backwards to the live spurring socket but havent actually even touched it, just threaded wire through walls, bolstered out for the back boxes and connected dead sockets, then called my electrician to come to check, he then rightly informed me (on phone) that it could be a radial circuit and different wire might want to be used.(5mm??)
5. Thank you to most of you for some of your comments....... There actually is some old bell wire in my shed, let me know if you want it and Ill stick it up on ebay!!! :D
So waiting for electrician to visit on the off chance he gets (recently retired electrician, pre heart op:()
What advice can you give in the meantime......... Im aware the first maybe to contact a qualified registered engineer in my area thats not about to keel over on the job, maybe you can help me out if your one.... Hastings, UK
Cheers
Liam
Liam I suggest you buy a copy of bs7671 before doing this, or the onsite guide, think about it.....how would a joiner know were to hang his shelves around diagonal cables?
There are no diagonal cables, maybe its just my crappy perspective drawing that makes it look like there is, only horizontal and vertical cables, (and I used a level!):o
Well maybe ill turn the single socket Im coming off into a 13amp fused spur, its hidden behind a bookcase and wardrobe anyway. Lets see what an electrician says first.
Couple of spurs (if possible) to run the cable and wire it up, aslong as you do the donkey work, I.e chase out for him, and patch back up, I wouldn't be charging more than £100, especially if it's a case of a unotifiable job.
If you wire it, and the kids get a belt, without at minium of 17th edition no judge in the land would deem you competent or even made the effort to become competent.......with no spark there whilst you run these cables you wouldn't be a "instructed person" you would be ruled as bs7671 states in the definition section a "ordinary person"
I once asked the B&Q garden expert if i could have a diesel lawnmower. After about half an hour he said yes, we will call you when we get one in. That was about 5 years ago, and he still hasn't rung.
Cheers............Howard
You'll need to borrow my strimmer then, let some light in!
meanwhile you've got a hairstyle like Mohammed.
perhaps his day job is with the DNO
Not dead! What wire to use when spurring a circuit onto additional sockets?
Australia
liamj2003,
telectrix,
