J
jjnr78
A few years back I carried out a pre work survey and discovered a contractor had installed the main protective earth bonds clipped direct externally. When I questionned him, he assured me he was using a UV tolerant and weather-friendly cable that therefore complied. It was a brown cable which he then identified green/ yellow at the termination points, which were internal.
I'm currently on a project which requires a 10sqmm earth to be installed on the opposite side of a property and there's no feasible method of installation internally (solid floors, fininshed decor etc). Typically I would use 20mm black conduit etc, but this is an addition which has cropped up and I'll be swallowing the costs, so the earlier mentioned method seems attractive. It would be run at high level which reduces the risk of mechanical damage, but its not a cable I'm familiar with.
Has anyone else used/ is using this method?
