danesol
Today, was a bad day for solar generation for us, any power been generated was used internally by the dishwaster etc etc, however some was avail to the solar immersion device, but very little, so my wife had to turn on the Gas Boiler ( 3yr old Valiant Condenser boiler ) at 6pm'sh to ensure she had hot water for her bath, so I found it was time to see just how much it costs to heat semi hot water via the gas boiler - here are my findings, even though the water had been preheated now and then by the immersion device.
Reading after boiler shut off ( Both reading and pic taken after 50mins ) - 2949 [28] 2
Reading before ( picture taken of meter prior to boiler been switched on ) - 2949 [16] 3
Total gas used = 0.12 units
Convert to kwh via multiplying by 31.5
= 3.78kwh
Cost of that gas 3.78 @ 3.45p per kwh = 13p ( ignoring std charge for this exercise ! )
Therefore rounding up to 30p for 2 heats per day - to allow for a colder fill and still an estimate as winter mths would cost alot more, over 365 days a year that would cost 30p x 365 = £ 109.50
Even using my exact reading for one heatup from been preheated - still would cost £ 94.90 p/a
So my previous estimation of £ 80 saving using my Solar Immersion Device could be well under and the saving even for GCH users could be more than you think ....... food for thought
Please check my calculations and comment away.....................
And the cost of the Immersun device, including installation for those that would have to pay?
I paid £ 249 +pp and fitting was FREE - so I recon' now pay back could be after just 2yrs as others had stated previously, as I had estimated a ROI of at least 3yrs before I decided on a purchase
It's good to be able to confirm return on investment.
If only I could persuade the tree huggers to let the Council tear down the 100 year old Oak trees that shade my roof I might see the same return.
Update:- Based on a calculation on another thread for June's Gas bill - it appears that £ 8.00 a mth to heat a hot water cylinder twice a day for 2 hourly periods is more or less correct for my particular setting, therefore I recon' in the good PV mths you will be saving roughly and on average between 7-12pounds per mth if you have one of these immersion switches fitted !
The more energy you have surplus and the more water you heat, the better the saving IMO !
My cost of heating water today when PV Solar Immersion not available !
danesol,
danesol,
