Galv will be easier to dress along 200yards than swa
SWA into galv t boxes with a stuffing gland at each fitting for me please? Volt drop will need to be considered as mr B stated.
5x 80w LEDs , so minimal load.. thinking 1.5mm should be ok but will likely run 2.5 to be safe. Not even sure contactor will be required , may split load into 2 DTD or perhaps even one will do need to check switching load been while since fitted one ?
starting to think armour would be pretty quick , 2 men cherry picker , chalk line , hold , clip hold, hold , clip ....gland...box light , hold clip hold clip...
At my pace Ill rattle 200 yards in a day ;P
- - - Updated - - -
1.5? 200 mtrs? hmm
200 yards , around 180m , but like I said will likely do 2.5 anyway
Me likes galvo, plastic if you have to, swa possible, micc love it,fp never worked with it.
quoting around 4k including VAT,
Require x5 80w LEDs, few drums or armour or conduit plus singles, accessories etc.
Cherry picker for 1 week , all very basic runs and routes ....
what you think ?
FP is useless as far to soft!, galv would be my choice, if it's a straight run then it's about 65 lengths, with a thro box every 9m, you can get away with saddling galv on a horizontal plain every 800, where as SWA will need clipping every 300 on the horizontal, two of us could put that lot up and have it wired in 3 days.
SWA is your other alternative but be warned, 6x2.5 and 3x 1.5 conductors in a t box will be bordering on a bit tight.
what you think ?
Well without actually costing the materials myself I cannot confirm the price either way, however first impression it seems a good quote actually, works out about 3,250 ish plus vat.
3" galv tray on stand-offs then cable tie SWA. future proofing for any new cable runs.:drool5:
sounds like you've recovered from your sourcreamflow binge.
Reactions: 2 people
Which conduit ?
Guest569,
Knobhead,
