Haha thanksThe invoice for the design consultation will follow shortly.
Discuss 3 x 1.5kw heaters on one circuit in the UK Electrical Forum area at ElectriciansForums.net
Has the heating requirements been calculated properly?
you may find that 3 x 1kW heaters would be enough.....
or..... you need something like 3 x 2.5kW!
Why a 4mm RFC? it is a recommendation that loads of > 2KW have their own dedicated circuit, IMO a 4mm RFC is the wrong solution.not exactly calculated, but as I’m installing a 4mm ring circuit, I’ll probs upgrade to 2kw heaters
you maybe correct, still don't like itBut that recommendation is mainly aimed at people who may put large loads on a ring which is used for other things as well. This ring is purely for the 3 hears.
Reply to 3 x 1.5kw heaters on one circuit in the UK Electrical Forum area at ElectriciansForums.net
