E
EWebster
Hi all,
I'm quoting on a 4kW installation which is 200 metres from the consumer unit. I've worked out that 25mm cable will be required to compensate for voltage drop.
Can someone confirm this for me, and make any suggestions as to any other gotchas or improvements I should be looking for?
Many thanks
E.
is that ac or dc cable you are talking about?
Why are you going to put an earth rod in?
4kW installation 200 metres away
Thread Tags
EWebster,
poheZ,
