M
mcfcdwa
hi everyone first message on here, im sure it is simple to mst people,i need to know if the outer metal strands on an armoured cable MUST be earthed. it is from the board to a garage at the bottom of the garden and the earth is run in the black cable, neutral in grey and live in brown or red cant remember
the armour must be earthed at the source,as it is an exposed conductive part.whether it is used as earth for the installation it supplies is another matter
Yes, It should always be connected to an earthing terminal, but does not necessarily need to be connected at both ends.
thankyou for your reply.so it can be earthed from the garage end as it has been stripped back at the source end to fit it into trunking
It can still be earthed at that end.
You would use an SWA gland, and then connect an earth conductor to the gland.
wind up..
im sorry i know it sounds dumb i currently do electrical work and was taught by someone who also was not qualified i am currently saving to go for my qaulifications,the reason i asked is that the electricians that where there before did not do that i thought you had to but had to be sure as it is important to be safe
i know it as the blind leading the blind
armoured cable should it be earthed
Thread Tags
mcfcdwa,
alarm man,
