Discuss Bog down on circuit but pick up on other in the UK Electrical Forum area at ElectriciansForums.net
I live in a duplex with an old Murray split bus panel. The issues I'm having atm are I have stove top but no digital oven controls. My dryer will just hum and dim lights. And my washer, fridge, microwave, and toaster will all bug down if I try to use them and dim the lights. But on another circuit at the same time will pick up. For example in the livingroom the box fan will go into hell yeah mode. I have the dryer on a 50 double the stove on a 50double and the main lighting on a 50double. The water tank is on a 30double.i have ground to service and a ground to water line. All outlets read fine untill a heavy loads put on. Idk wth to do
Sounds like an open or poor connection on the neutral, possibly even your incoming supply, as USA often has split-phase arrangements (120-0-120V). Hopefully some of our USA folks can comment.
[automerge]1600078236[/automerge]
The safest advice is to get a professional electrician in to look at it, more so if it involves your incoming supply. Mistakes with that can end very badly. Also before you do anything yourself check if your house insurance would permit it.
Silbuagh it sounds to me like your problem is in your panel, possibly a loose connection. I have been called to go out and troubleshoot problems similar to yours and with the old murray Panels and I’m sure that you need to have your service upgraded. Over time the main breaker is bad about breaking down from the stabs in the back where it is attached and you have 1 phase trying to carry all the loads. Hire an electrician to further advise you
Yes it does sound like a bad neutral connection. Get it fixed now, because when one leg can go way over 120V and kill the appliances connected to it.
Reply to Bog down on circuit but pick up on other in the UK Electrical Forum area at ElectriciansForums.net
I have a Single Phase Power box for a townhouse. When I read voltage across the Hot legs (A) and (B) to ground I get 123 volts with the main...
I have the typical LED on Dimmer switch. All the lights flicker in my house are very inconsistent times. By let me clarify by saying all the...
Hi I was trying to get some help with this problem I’m having in my house , I recently did some remodeling in my home and decided to put a...
Background is we are selling our house and moving out of state. I've been fixing big and little things and painting for several months now, as...
my lights are dimming everytime an appliance turns on in my appartment and the shared area of the basement next to it. my fridge causes a moderate...
