- Mar 21, 2011
- 13,191
- 11,409
- 18,688
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Retired Electrician
I'm sure this has been asked before, and I have done some searching here, but not quite sure how to phrase it to search properly.
I have just completed some minor works on a property installed to the 16th, i.e. no rcd's on lighting. The client required replacement of existing ensuite lighting, like for like (to Zone 1 fittings). I checked with Elecsa, to make sure this was acceptable. There was supplementary bonding in the ensuite bathroom, although there was non evident in the water heater/imersion cupboard, although the continuity readings were low (decided to cross bond here anyway).
My question is how to complete the Minor Works Cert. Part 1, sec 'Departures from BS7671 2008'. How do I complete this section in the above circumstances?
