Contact Machine Mart Technical advice either by Email, phone or fax
FREE Technical Advice, 6 Days a week
Monday to Friday 8.30am – 6pm
Saturday 8.30am – 5.30pm
Tel: 0871 410 1260
Fax: 0871 410 1265
Email: [email protected]
I bought a 3kw log saw from machine mart a few years back, that came fitted with a 13A plug, which obviously kept blowing!
I e-mailed them and they eventually conceided that it needed to the changed for a 16A plug, which they supplied FOC.
Sorry to drag up an old thread!
Rich
I have had the same problem the answer was the non return valve. There is a nut on the valve this houses a spring and a thick rubber disc. This had stuck open causing the compressor to start under load. Cleaned and replaced problem solved.
Yep, thats your problem the NRV (non-return valve) it was stuck or if the compressor is old sometimes/most cases only the spring is presented and no sign of pastel (the rubber thing). There are service kits for these valves or a new valve (£20-£25)
