P
Paul Jennings
Hi forum,
I’m planning some garden lighting and would like to try an minimise the amount of cable I’m using. I have a number of different lights/circuits in one area of the garden so was planning to run a multi core cable to a convenient place then make connections from there. All the lights will be LED and so very low voltage. Can I run eg a 12 core 1.5mm cable then Connect various 3 core 1mm cables to this? Or should the cable cross sections area all be the same?
Thanks in advance
Paul
connecting with wagos or connector blocks will be fine.
  • Agree
Reactions: James
Cable size is determined by current, not voltage. If you're using the cable to supply the light fittings with 12 Volts you need a much larger cable than the one upstream that's supplying 230 Volts to the power supplies/drivers.
I'd suggest you at least pay a sparky an hour for advice and help with the circuit designs even if you're going to do the installation yourself, I think it will work out cheaper in the long run.
  • Agree
Reactions: Pete999
Thanks for your replies, I couldn’t get hold of my electrician so thought I’d ask you guys. He also confirmed wago boxes will be ok so long as they are in a weather proof box.
Different core size connections
Lighting Forum
Paul Jennings,
Paul Jennings,
