Discuss Fuse as main isolator ? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
carson
Sent to a job today to carry out a pir on the stair lighting & mains supply for the door entry system the problem I have is that both are supplied from an unmetered supply via a gec safelip bs88 fuse rated at 15 amps. Does a main isolator need to be fitted or does this fuse count as one.
perhaps it's unmetered to the tenant's meters but supplied from a landlord's meter elsewhere. so as the usage is paid for by the landlord, not the tenants.
Reply to Fuse as main isolator ? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Hi everyone, A diversity question concerning 2 consumer units fed from 100amp DNO supply Background, So I have an 18th Ed compliant consumer...
Hello All Can I say to start with I am not an electrician but used to be a heating engineer (yes I can hear the groans). I have wired the...
14K
