Discuss Gov announce no new petrol or diesel post 2040 in the UK Electrical Forum area at ElectriciansForums.net
Cheers for the input,but it is not "pollution free"...not if it has been constructed with processed plastic,metals,paint,glues,fabric,oils and greases,and uses or requires electric charging generated by conventional means. Let us not forget the decommissioning of the several battery packs it should use during it's life cycle...then the vehicle itself....
In truth,the only truly pollution free part,is the travelling done,in between charges...if it does not leak any oil from it's gearbox :)
surely that's the important part... Due to the fact it kills people and wildlife? and it doesnt have a gearbox, so no leaks.. batteries etc are recycled, our lungs arent.
Peg makes a very good point that is often overlooked in my opinion. These electric vehicles are not quite as pollution free as they are made out to be - I saw one the other day that had a "0% pollution" badge on it, what rubbish! And the batteries are full of really nasty chemicals that will have to be disposed of somehow?? The thing that makes me titter though, is the fact that apparently, 72% of motorway "breakdowns" are Burks running out of fuel. Can you imagine what it's going to be like when they have to charge the car every time? We will need at least 2 hard shoulders.
Jes', your back sparksburnout. Better dig out my copy of Oxford Dictionary :eek:
Hi dude,i apologise,i should have said,if it leaks any oil from it's four mode single speed automatic gearbox...which it is fitted with :)
I'm not having a pop...just proving how easy these eco-myths are formed.
I do not doubt that at some stage,you were told,or lead to believe,it had no gearbox...it sounds kind of understandable,but drive-trains,regenerative braking,hill start assist,etc all require a means of transmission.
It is the same story when folk are told,there is no pollution.
A slightly more thorough investigation,reveals the full story :)
Producing Lithium cells puts out far more harmful gasses into the environment than producing and running an normal petrol car. Coupled with the fact they need replacing quite often. (I'm not exactly sure if my memory is correct here, but I'm sure I read a 7 year lifespan.)
Even catalytic converters produce more pollution in manufacture than they save from the cars output over a 20 year life.
Guess what though, both are not made in this country. So who cares...
Is it not the point to remove pollution from our towns and city's , I do agree that with electric vehicle you are not preventing pollution its just going elsewhere .
I was walking past a taxi rank the other day, all had there engines running and I found it very unpleasant and thought this can't be good for my lungs
So in summery if we get all electric vehicles the planet will still be destroyed but we will be able to breathe fresh air in our towns and city's until it does.
Well at some point (well past my sell by), we'll run out of fossil fuels and will be needing some other form of sustainable fuel (got my money on plutonium-powered nuclear fission reactor).
Ps Feeling a bit uneasy with my multiple use of well, will etc, sparksburnout and all that :)
I personally find it quite irritating when people just sit in their cars and leave the engine running, often for no obvious reason. I bet this alone causes loads of totally unnecessary pollution.
Reply to Gov announce no new petrol or diesel post 2040 in the UK Electrical Forum area at ElectriciansForums.net
Electrical2Go - Green2go Launches for All Your Solar, EV Charging and Renewable Needs Green2Go - for All Your Solar, EV Charging and Renewable...
Electrical2Go - Electric Car Charging at Home - Comprehensive Guide As EV ownership and the transition towards electric cars rise, having a home...
I'm fitting one of the Apex 7S units on Friday. I'd avoided the original range after a couple of bad experiences but I figured a new model might...
Afternoon all, and apologies if this has been covered elsewhere, but a search didn't bring anything up. Just a quick heads up to anyone...
There is a new form on the horizon for EV charge points. Some interesting criteria now apply, If you are not sure what the fuse is then you must...
6K
