Discuss Laptop keyboard replacement in the Computer and Networking Forum area at ElectriciansForums.net
J
Jonesy83
I need to replace my laptop keyboard I think as my clumsy missis spilt her brew on it then a few keys now stick whilst others don't work at all or stick on where can I find the exact model number or make all I know it's an acer
the labour charge to replace a keyboard is not a lot. i'd take it to your local pc doctor.
Usually model number and details are stamped on the bottom of the laptop. You can then search for replacement keyboard. They are just held on with a couple of small screws and can just be unplugged and swapped in 5 minutes.
I take it the label underneath it worn out, try this
Go to windows run...
type "dxdiag"
Should be a line which tells you the model
Reply to Laptop keyboard replacement in the Computer and Networking Forum area at ElectriciansForums.net
My ASUS laptop has been sort of broken for a while, instead of replacing it we thought that it might be repairable? Its missing both hinges and...
Hi,… Is the N50 Series of Neff ovens a replacement for the Series 3? and secondly where can I find information on the meaning of the alpha...
Hi, as the title says, I need to change the upper heating element on my HE10AB220/C oven. I've never done that and it seems pretty easy, as in...
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
I need to replace two AFCI breakers on our main circuit panel. I have replaced and added breakers to our sub-panel several years ago. When I...
