Search the forum,
Discuss Lutron in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
S
Sly
Hi Gentlemen,
I’m supposed to make a certificate for a big private property. In the house, there is main consumer unit with 40 circuit breakers. There are also another 3 Lutron units (32 breakers each) which are supplied from the main consumer unit via three B40A breakers. There is 96 C10A breakers (96 light circuits).
I’m not sure if I can write all circuits to one certificate (40 breakers in main unit + 96 breakers Lutron units) or I need to make certificates separately for each unit.
Hi Gentlemen,
Where are you working mate,in a stately home.Take it the supply is 3 phase.Do they have their own power station:rolleyes:
Whos house is it? the royal family.
Two options come to mind everytime you start a new dist' board start a new continuation sheet with the first been dist board 1 and all its outgoing submains, or a new report per board but you only end up repeating yourself.
Did a job like that last year with 4 lutron boards,local inspector made me do a cct description for every cct on main dis board and every mcb on each lutron board.Took me two days of paperwork!,was not happy ,customer sold the house 3 months later and new owner had the place gutted!:mad:
Reply to Lutron in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
Hi everyone, A diversity question concerning 2 consumer units fed from 100amp DNO supply Background, So I have an 18th Ed compliant consumer...
