Discuss Medium size shop. Full concrete construction etc .Basement with 2 fire exits.Fire /smoke alarms? in the Commercial Electrical Advice area at ElectriciansForums.net
LukeD
As title !
Single entry ground front door. twin stairs to basement . Each side of basement (It was knocked into one years ago) has its own fire escape etc .
what would be the Basic level of Fire/smoke detection equipment that"should be required" for each of the 2 floors ?
As title !
What ever the fire officer and building control want.
Horizon did a documentary on this a few years back. Fascinating. With Alan Davis presenting. Length of string not fire alarms
Hmm...if you tie the ends together it isn't infinite really. IMHO. It can then be arranged as a circle with length = circumference, by pie arse squared.
If it was flat string with 2 distinct sides and you twisted it before joing the ends well then you would have a Mobius strip, which some might agree has infinite length...however, you would still meet the starting point if you actually measured it with a tape...
Oh, look...it's beer o'clock!
Contact your wholesaler and ask them to get their fire alarm supplier to do a survey or take a look at your plans. Most suppliers offer this service for E/Lighting and fire alarms for free and will comeback with a design. If you're not sure its probably best that you don't take the responsibility of designing it.
Reply to Medium size shop. Full concrete construction etc .Basement with 2 fire exits.Fire /smoke alarms? in the Commercial Electrical Advice area at ElectriciansForums.net
I need a fire alarm installing in a house that was converted into flats 30 years ago. It comprises 3 units. Ground floor and basement maisonette...
Hi all I have a small problem with a job im doing, 2 first floor flats above a shop with separate landlords area for the 2x flats which is a...
Hi, I have a common area above a shop which is a small hallway leading to 2 flats. Each flat has 3 smoke alarms, one behind their front door...
7K
start my largest rewire next monday -5bed over 4 stories 2 things I want to iron out before I start really.... 1) I have quoted for installing...
Any info would be greatly appreciated. I have just rewired a HMO and have now been asked to do fire alarm and emergency lighting. I have wired...
