Discuss Megger Mft 1552 in the UK Electrical Forum area at ElectriciansForums.net
S
stuartgil
Just managed to bag myself a great deal on a second hand mft 1552, Won it for £300 on ebay although no calibration cert, every other test lead is included in the sale plus the charging unit and batteries. The guy told me that getting the unit calibrated is expensive and to register myself against the machine instead, tbh I'm at a bit of a lose, I thought calibration is around 60-100 mark! :willy_nilly:
cheers glenn and jay, I will replace all leads if needs be, would a local electrical supplier do the calibration or do I need to look on line? thanks for advice once again.
go for value for money....good callibration houses will allow 24 hours in a climate controlled room for instruments to `normalise` before puttin em on the rig....
which begs me to ask why my part pis assessor tried offering me `callibration` out of the back of his car....
loads of calibration services around. wholesalers occasionally have cal. days where it's discounted. at a losss where you say batteries and charging unit are inc. as megger advise not to use rechargeable batts.
Quite right tel, the 1730 is rechargeable I believe, definitely not the 1552 as you rightly mentioned.
Reply to Megger Mft 1552 in the UK Electrical Forum area at ElectriciansForums.net
I have a nice new KT66DL MFT and a spare fluke. The KT64DL is now surplus to requirements and going to off load it. Before going through all the...
Hi, just got a bit of a shock this morning, turns out my Megger has failed calibration and needs to go back to Megger for a "fixed price" repair...
8K
i have seen on ebay an advert for calibration of equipment, with a turn around time of 48hours after receiving your tester. for a total £35...
J
I recently bought a megger 1730 and i`m getting some weird earth loop readings using the no trip function. I know they can be a little higher at...
N
Megger MFT 1552 multifunction tester for sale mint condition , this was a spare unit so original cal has ran out virtually unused ,lead set has...
chrisgc
C
