telectrix
Mentor
Supporter
Sep 5, 2010
71,498
72,015
18,688
78
cheshire/staffordshire
United Kingdom
Electrical Engineer (Qualified)
Business Name
Telectrix
had the misfortune to help my lad on a CU change. yesterday. he'd got a dual RCD MK 10 useable way CU. design problems as follows.
1. rear knock-outs (4) all 32mm, no big hole so cables dressed iton different holes,
2. 32mm knockout in bottom for tails directly under main switch so no clearence for tails, when there's a huge space to the left of the switch.
3. top entry knockouts all 20mm so a circuit per hole.
minor probs compared with the rent a roof solar monkeys.
1. RCD and MCB from invereter in 2.5mm T/E, box secured on wall with 2 x 1" screws into plaster, no plugs.
2. Henly block fixed with 1 loose screw.
3. all terminals loose, requiring 1/2/ to 3/4 turn to secure.
4 every terminal with exposed copper showing.
Reactions: pc1966
And you were so shocked, you forgot to take photos.
I would loved to be a spider on the wall
When The work was done,f@@@@@@@k s@@@k.lol
Reactions: pc1966
A lot of SP Henley blocks seem to only have one knockout for a screw meaning they've always got potential to spin .. poor design.
Why only one circuit per hole with the 20mm knockouts?
Use a cone head cutter on the MK holes and you can expand the 20 to a 25 ?
  • Funny
Reactions: Dartlec and loz2754
BG suffer from this design issue too, though it's on the right. I have no idea what the idea was - maybe they forgot to put a hole in somewhere in the design process...
Possible to add a hole with a cutter of course, but still daft.
I like the Hager boards as you can buy them without knockouts. I wish most things came blank so you can cut the holes in any position size you need. Same with some outdoor sockets, why on earth does a 16A outlet need a pre cut 40mm threaded hole in the top, what am I supposed to do with that??!?
telectrix
Mentor
Supporter
United Kingdom
Business Name
Telectrix
MK CU
Thread Tags
telectrix,
freddo,
